Change notifications on Slack and Discord
Distill integrates with third party services to send instant change notifications. Integrations for Slack and Discord use webhooks. This is a premium feature which is available to all paid customers. To configure webhook actions, checkout following steps.
Slack Incoming Webhook
Checkout https://api.slack.com/messaging/webhooks#getting_started to create an incoming webhook URL for a channel. Once you have followed the steps, you should get a URL that looks like this:
https://hooks.slack.com/services/T00000000/B00000000/XXXXXXXXXXXXXXXXXXXXXXXX
Copy this URL and follow these steps:
  1. Go to the monitor’s Options page in your Watchlist at https://app.distill.io
  2. Click “Add action” > “Slack Notification” under Actions section.
  3. Paste the webhook URL in the input box as shown below and save.
Slack change notification action
Subsequent changes to the monitor will sent to the channel configured in the Slack incoming webhook.
Discord Webhook
Checkout https://support.discordapp.com/hc/en-us/articles/228383668-Intro-to-Webhooks to create an webhook URL for Discord. Once done, you should get a URL that looks like this:
https://discordapp.com/api/webhooks/400000000000000/XXXXXXXXXXX-XXXXXXXXXXXXXXXXXX
  2. Click “Add action” > “Discord Notification” under Actions section.
Discord change notification action
Subsequent changes to the monitor will sent to the channel configured in the Discord webhook settings.
