How to view logs of checks?
What is Check Log?
Check log stores log information of time for the recent 20 checks. If a monitor encounters an error during the check, the time is shown in red. You can click on the error code to view more details about it. To view the check-log, click the “last changed time” as shown below in the image.
Please note that the check log is only shown on the device where the monitor runs for checks and is not synced across the devices. “Last changed on” time is the time when the latest change was detected. The time shown is in your local timezone.
In case of an error, check-log registers an error with code. You can click on the error code to get more details on the error. Check out the Troubleshooting common errors page to get help on the errors. Monitors running with errors can be viewed all at once from the Error folder. In the case of 10 consecutive errors for a cloud Monitor, the Monitor switches off automatically.
