Using Labels to Organize Watchlist
One can associate a monitor with one or more labels. It is useful when you have lots of monitors and they need to be organized into different categories for quicker access. Monitors under one label can be viewed in just one click from Watchlist.
How to use labels?
To use labels, you need to first create new label names. Once labels are created, you would be able to see them in the dropdown of label icon.
You can follow these steps to create labels and add to monitors:
Step 1: Click on “Add Label” from Watchlist. It will open a Label window.
Add label
Step 2: Add the label name in the highlighted box in Label window and Save.
Label name
Once you have added label, it will appear in the Watchlist as shown below:
Label news
Step 3: You can then click on a monitor and select the desired label from the label menu as shown below:
Labels
The labeled monitor will appear in the Watchlist as shown below:
Labeled monitor
