Running Local Monitors
Distill Web Monitor enables organizations to run local monitors through the browser extension or desktop app. This is particularly useful for scenarios where cloud-based monitoring is not suitable or possible.
Common Use Cases for Local Monitoring
Scenario Why Local Monitoring is Needed
Difficult-to-monitor pages Pages that frequently block cloud-based requests
Geo-location specific content Requires access from a local IP when proxies are insufficient
Login-required pages Maintains active login sessions without repeated authentication
High-frequency monitoring Local monitoring supports intervals as low as 5 seconds (cloud minimum is 1 minute)
Understanding Local Monitoring in Enterprise
Local monitors are checks performed from a user’s browser (via extension) instead of the cloud.
In multi-user Enterprise setups, visibility becomes important. If local monitors are not correctly scoped, they remain private to the creator’s device — which can lead to:
  • Missed alerts by other team members
  • Inability to manage or edit monitors centrally
  • Duplicate monitors being created by different users
To ensure visibility, monitors created from the browser extension must be associated with a Primary Workspace.
Device’s Primary Workspace
A Primary Workspace determines where local monitors from a device are stored and who can access them.
Monitors can run locally on a device (browser extension) only if they belong to that device’s Primary Workspace. You can change the Primary Workspace from the extension settings.
A device’s Primary Workspace can be either:
  • Your personal workspace, or
  • A shared workspace
If you want monitors running on your device to be visible to your team, set a shared workspace as the Primary Workspace.
When to Use a Shared Workspace as Primary
You may want to use a shared workspace as the Primary Workspace in cases such as:
  • Running monitors that need to be visible to other team members
  • Ensuring alerts and monitoring history are accessible to the team
  • Allowing other users to edit or manage monitors created on your device
  • Avoiding duplication of monitors across different users
Setting Up Primary Workspace
  1. Open the Distill Browser Extension
  2. Navigate to the Watchlist
  3. Click the ⚙️ Settings (gear icon)
  4. Scroll to Primary Workspace
  1. Select your team’s workspace from the dropdown
Teams Workspace Dropdown
  1. Click Save
Note: This setting applies per browser/device. If you switch browsers or machines, you will need to configure it again.
Desktop App Support
In addition to the browser extension, Distill also supports local monitoring via a Desktop App.
  • Does not use browser tabs for running checks, so it does not affect your browsing experience
  • Works with websites that require an active tab to load properly (which may not function reliably in browser-based monitoring)
Summary
Local monitoring allows checks to run from a real browser environment, which is useful for restricted or dynamic pages.
Primary Workspaces ensure that monitors created from the browser extension are visible and manageable within a team environment.
Need assistance setting up your Primary Workspace across the team?
Contact Distill Support for deployment guidance and onboarding help.
