JSON Monitor
Available in Starter plan and above
What is a JSON monitor?
JSON (JavaScript Object Notation) is a standard format for data interchange on the web. It’s widely used in APIs and web services for its efficiency in organizing data and ease of parsing.
A JSON monitor automatically tracks changes in JSON data at a given URL and sends alerts when the content, structure, or values change. This is useful for monitoring:
- API responses and endpoints
- E-commerce product data
- News feeds and aggregators
- Financial services data
- Social media platform APIs
- Real-time data feeds
URL parameters
JSON monitors automatically load URL parameters (key-value pairs) if present in the URL.
Click Add Query Param to add additional parameters or headers as needed.
Supported HTTP methods
- GET — Retrieves data from a resource (most common for JSON monitoring)
- POST — Creates a new resource
- PUT — Replaces an existing resource
- PATCH — Partially modifies a resource
- DELETE — Removes a resource
Set up a JSON monitor
Open the Watchlist at https://monitor.distill.io or in your browser extension
Click Add Monitor → JSON
Enter the web service URL you want to monitor
Click GO to send the request
Select the properties you want to monitor using the checkboxes
Click Save to open the Options page
Configure check interval, alert actions, and conditions
Click Save to add the JSON monitor to your watchlist
