Using Watchlist
The Watchlist collects all your monitors. Use it to view, add, and manage them.
This is how your Watchlist will look like:
Watchlist - List of monitors
What is a Monitor?
A monitor is a single webpage with a unique URL added to Distill to watch for changes.
How to view Watchlist?
You can view and manage the Watchlist from the browser extension or the web app. When you’re logged in through the extension, Distill syncs all monitors to the cloud so you can access the Watchlist anywhere.
If using browser extension, click on Distill icon from toolbar → Click on “Go to Watchlist”.
Distill Menu Popup
If using Web app, sign in to your Distill account to view Watchlist.
Watchlist User Interface
Following is a screenshot showing different elements of Watchlist.
Watchlist - Explained
From the Watchlist you can act on a single monitor or on several at once. Select one or more monitors to view the available bulk actions. To edit an individual monitor, click the down-caret icon beside it. The screenshot below shows the main action buttons in the web app. In the browser extension, two extra buttons—sync and check for changes—also appear.
Actions in Watchlist
Here’s a video tutorial that will help you navigate and efficiently use the Distill watchlist.
