Website Monitor
Available in Professional plan and above.
A Website Monitor lets you track changes across multiple pages of a website using a single monitor. You can monitor an entire website or a specific section, such as a newsroom, blog, or help center, without manually adding each page URL.
A Website Monitor detects three types of changes:
- Added pages: Pages newly discovered by Distill, including newly published content.
- Deleted pages: Pages that are no longer part of the monitored set. These may still be online.
- Modified pages: Content changes on previously monitored pages.
Website monitors run in Distill’s cloud.
Website Monitor vs. Webpage Monitor
Use a Webpage Monitor when you know which page or part of a page you want to track. Use a Website Monitor when you want to track multiple pages and discover new ones automatically.
| Webpage Monitor | Website Monitor | |
| Monitoring scope | One webpage or selected elements | Multiple pages within the configured website scope |
| Page discovery | You specify the page URL | Distill discovers pages automatically |
| Changes detected | Changes to monitored content | Added, deleted, and modified pages |
| Example | Track a product’s price | Track changes across a product website |
Use cases for website monitoring
- Competitive intelligence: Track new product pages and changes to existing product descriptions or pricing pages.
- News and press releases: Discover new announcements in a company’s newsroom.
- Regulatory monitoring: Follow new publications and updates to existing guidance.
- Documentation monitoring: Track new guides, API updates, and changes to existing documentation.
How website monitoring works
Distill starts at your Start URL and follows links to discover pages within the configured host and path. You can also configure sitemaps to help it discover pages that are not linked from other monitored pages.
The first completed check establishes the baseline. Subsequent completed checks compare the discovered pages and their content with the previous completed check. Distill can then detect added, deleted, and modified pages and trigger your configured alerts.
A Website Monitor covers the pages Distill discovers within its configured scope, not necessarily every page that exists on the website. You can inspect the discovered pages after the first check.
How to create a Website Monitor
- Open the Watchlist. Click Add Monitor, then Website.
- Enter the Start URL of the website or section you want to monitor.
- Click Done. In the monitor options, give it a recognizable name, such as “Woodgrove Help Center”. Under Actions, choose how you want to receive notifications.
- Click Save. The default schedule is once a day.
Choose a Start URL
| Start URL | Monitoring scope |
https://help.example.com/ |
Discover pages across the help website |
https://help.example.com/account/ |
Discover pages under the account section, excluding other sections such as billing |
https://community.example.com/ |
Discover pages on the community subdomain |
A subdomain such as community.example.com needs its own monitor. To further narrow the scope, see Exclude pages from monitoring.
View monitored pages
After the first check, the Watchlist shows a count such as Monitoring 148 URLs. Click the monitor’s preview to open Change History, then click Explore Site in the first entry.
In Explore Site, you can browse discovered pages, search for a URL, inspect how it was discovered, and see why a discovered URL is not monitored.
For example, search for /account/two-step-verification/. Select it and open Crawl Path to see how Distill reached it. If a URL has a Not Monitored badge, hover over it for the reason. If an expected page is missing, check how Distill finds pages.
View website changes
Distill compares each completed check with the previous completed check. When it finds a change, it adds an entry to the monitor’s Change History and can trigger your configured alerts.
See what changed in the Watchlist
After a check that finds changes, the monitor’s row shows a count for each kind of change, followed by text from one of the changed pages. Hover over a count to read it, such as 3 pages modified or 1 page added. Deleted pages get a third count.
Click the row’s preview to open Change History.
Read a Change History entry
Each check that finds changes adds one entry, with the newest at the top.
- Added lists pages the monitor picked up in this check. A guide can appear here the first time another monitored page links to it.
- Deleted lists pages that have dropped out of the monitored set. A guide can still be online after the site removes the last link to it. Open the URL to check.
- Page-Specific Changes lists pages whose content changed, each with the text that changed. Green text was added and red text was removed. The numbers beside a page title, such as
+1 -1, count the pieces of text added and removed. - The bell shows whether this change triggered a notification.
An entry leaves out changes that repeat on several pages, such as a new link in a shared menu. This is why the Watchlist can count more modified pages than Page-Specific Changes lists. To see every change, click Explore diff.
Explore every change in a check
Explore diff opens the Changes page for that check. Clicking a page title in the entry opens the same page with that page selected.
The list on the left groups the changed pages:
- Added Pages and Deleted Pages hold the pages from Added and Deleted.
- Page-Specific Changes holds pages with a change that no other page shares.
- Repeated Changes has one item for each change found on more than one page, with the number of pages. Hover over the item to preview the change. Expand it to list the pages.
Select a page to see it on the right with its changes highlighted. Above the page, choose how to view it:
- Simplified shows the page’s content with plain formatting. Visual shows it with the site’s own styling, Text shows only its text, and Source shows its HTML.
- Deleted shows or hides removed text. Snipped hides unchanged content, and Images shows images.
The top row tells you which checks you are looking at:
- The time beside the monitor’s name is the check you are viewing. Click it to choose another check.
- The time at the far right is the earlier check that it is compared with.
Compare two versions of a page
Above a selected page, click Explore diff, outlined in the previous screenshot, to open that page’s versions next to each other.
Side-by-Side Diff puts the earlier version on the left and the later one on the right. The two outlined menus choose which versions to compare, and the arrows above each side jump to the previous or next change.
Find out why a notification was or was not sent
On the Changes page, the bell in the top row shows whether the check triggered a notification. Click View Conditions beside it to see the conditions that applied to that check, together with the text and URLs that the check added and removed.
Stop monitoring a page that changes too often
In the list on the Changes page, open the menu beside a page and choose Exclude URL. Distill adds an exclusion for that page’s path and saves it right away. To undo this, remove the exclusion under Excludes in Edit Crawler. To leave out a whole section, write the exclusion yourself.
Configure alerts for website changes
Open the monitor’s menu in the Watchlist and choose Edit Options. To get email alerts, check the recipient under Actions. If you need to add an email action, click Add action and choose Email. With no conditions, changes to any monitored page can trigger the action.
For example, to get an email when a guide mentions a deprecation, add a condition under Conditions. Choose Added text, select contains, enter deprecated, and click Save. Adding “This endpoint is deprecated” matches. Adding only “A guide is available” leaves the change in Change History without triggering this email. See how to combine conditions. To check which conditions applied to a past change, see why a notification was or was not sent.
Configure page discovery and schedule
To change how Distill discovers pages or how often it checks them, open the monitor’s Watchlist menu, choose View Crawler, then Edit Crawler. After editing, click Save. Choose Run New Job if you want to check the new coverage now.
Include pages from a sitemap
If a guide has no incoming link from a monitored page, a sitemap can help Distill find it. Under Sitemaps, click Add Sitemap URL and enter the address of the site’s XML sitemap. Or turn on Auto-Discover Sitemaps to check /sitemap.xml and the sitemaps listed in the site’s robots.txt. Sitemap entries follow the same host, path, and exclusion rules as links. If a sitemap fails to load because of a server or network error, the run fails.
Under Excludes, click Add and enter a regular expression that matches the URL path. For example, ^/docs/archive(/|$) skips /docs/archive and the pages beneath it. A guide at /docs/archived-guides/ stays in scope. Exclusions only match the path, so they apply to every query string for that path.
Other examples:
^/careers(/|$)excludes the careers section.^/blog(/|$)excludes the blog section.^/(careers|blog)(/|$)excludes both sections.
Change the schedule
In Edit Crawler, change Schedule and click Save. A website is checked at most once a day. See Monitoring limits and cloud check usage for information about check consumption.
Advanced crawler configuration
Remove tracking parameters from URLs
If tracking parameters give the same guide several URLs, open Rewrite URL, then Edit Steps. Under Use Preset, choose Filter query params and list the parameters to remove, such as utm_source. Finish with the preset that returns the constructed URL. Enter a Test URL and check the Result before saving. Keep parameters that select different content, such as a guide’s language.
For example, removing utm_source from https://help.example.com/guide?lang=en&utm_source=newsletter leaves https://help.example.com/guide?lang=en.
Skip pages based on their content
Use Page Macros if a URL alone cannot tell you whether to include a page. For example, a macro can check for an “Archived” label and call skipURL when it finds one. The crawler also skips the links on that page, so any guide reachable only through it may drop out of coverage. If a macro step fails, such as a check that doesn’t find what it expects, the whole run fails and produces no change report. To leave a page out, call skipURL.
Website monitors run in the cloud and use your monthly cloud check quota. Each successful run uses at least one cloud check. Longer runs can use several checks, so do not assume that each scheduled run consumes exactly one check.
The URL limit controls the maximum number of URLs for a crawl. If a crawl reaches this limit, you can narrow the monitoring scope, exclude irrelevant sections, or raise the limit within your plan’s allowance. See URL limit errors.
Troubleshooting
A page I expected is missing
In View Crawler, find the run under Jobs and check its status. For a completed run, click its start time to inspect the pages it found. Check the missing page’s host and path against the Start URL, then check Excludes. If the page is in scope, look for a link from a monitored page or add a sitemap that lists it.
The crawl reached its URL limit
A run that reaches the URL limit ends with an error and produces no change report. Distill retries a failed run after a delay, but the retry stops at the same limit unless you raise it first. In Edit Crawler, raise the limit within your plan’s allowance, choose a narrower Start URL, or exclude sections you don’t need. Save the change, then choose Retry to continue the failed run or Run New Job to start over. See URL limit errors.
A page is listed as deleted but is still online
Deleted means that the page has dropped out of the monitored set, not necessarily that it has been removed from the website. Check whether the page is still linked from other monitored pages or listed in a configured sitemap. Review the Start URL and exclusion rules if you recently changed the monitoring scope.
Too many irrelevant pages or duplicate URLs are monitored
Use a narrower Start URL or exclude irrelevant sections. If tracking parameters create multiple URLs for the same content, rewrite those URLs to remove the unnecessary parameters.
A crawl failed partway through
In View Crawler, expand the failed job to inspect the error. If the site was temporarily unavailable, choose Retry on the latest failed job once the site is reachable. Retry resumes that job. Distill also retries a failed run on its own after a delay. If you changed which pages to include, use Run New Job to start a fresh crawl.
